1 - 20 of 32 Posts
Price aside would you get the Hotchkis or the Tien S-tech spring? I'm about to buy some springs with Tokico Illuminas and don't know which is better.
I heard that the Hotchkis are really soft in the back and rub or bounce alot.
...so price aside, which should I get out of those two?
id say hotchkis just cause they are on sale in the .net store
Bugaloo
Hotchkis :approve: they are soft in the back which prevents bouncing... The ride is similar to stock... the only disadvantage of have a lower spring rate in the rear, is with added wieght i.e. rear passengers... they tend to sag.. which can make nasty speed bumbs a chore..
Discussion Starter #7
...no one else? So what alot of you guys are saying is Hotchkis is better out of the two as far a comfort wise, correct?
I know both have a simlilar drop height but which is lower, do you know exectly?
I would get the s-techs. I love mine and always have four people in the car w/ 19's and hardly ever rub, only if i hit a big dip and fast speeds and even then its not that bad of a rub. I got mine off ebay for 145 shipped :bigSmile: cant beat that for those springs
Hotchkis and S-techs are on the different end of the spectrum. The s-techs are significantly stiffer in rate both front and rear and drop your car ultra low like the H&R springs.
If you hardly EVER have any passengers or weight in the car, and dont care about scraping here and there, and having negative camber, go with the s-techs.
damn it's hard to tell which to go with because everyone has their own opinion... "AltezzaBob" would you recomend Hotchkis to someone who rides with passengers in the back?
I have loved my Hotchkis springs since day 1! I haven't experienced any problems with rubbing. With more people in the car though, the IS rides nice and low. I love how it looks! I think the only time you would rub would be backing out of a parking spot with the wheel turned all of the way to one side.
Hotchkis for stock rim/tire, strongly agree. S-Tech for aftermarket rim/tire, agree.
with passengers in the back all the time, i would say no. since the rear would sag alot lower than stechs with passengers in the rear with such lower of a spring rate, even MORE negative camber = hardly any rear tire road contact and bouncy in the rear.
any camber kit out there to cure this negative camber issue? I saw and read a few threads but seems like there's no one outthere offers a kit.... :(
OKCIS said they were bad when he had them. I dunno. I personally like the looks of the stechs. They look great.
hmmmm....glad i have no friends to put in the back of my car when i finally get my hotchkis' installed....
I have 18x7.5 and 225/40/18 all around and have no problems on the hotchkis. I've had 4 people in my car before and didn't have any problems. Maybe speed bumps would be an issue though.
I have the s - techs with Tokico Illuminas shocks and I love the set up. Its very comfortable and rides almost like stock on the low settings. I had three people in my car this weekend and hit a huge dip in the road that I didn't know was there and didn't bottom out or scrape. But it is a hard choice because I road in a IS with the Hotchkis springs and stock shocks and it was a great ride too. good luck
dont think there is a camber kit. i've seen alot for sale and advertised, just neve bought it myself, or seen it, installed it or heard much from people installing it.
altezzabob, i did search and somewhat found out that the hotchkis springs will settled at 1.5" all around. is this true? and another thing, what type of shocks/damper would you recommend for hotchkis springs? koni adjustables are looking good, along with tokico illuminas :)
thanks!
1 - 20 of 32 Posts
