I made this using Phoenix Gold 8 and 4 gauge wire and one of their distribution blocks. I plan to run one more wire to the servo on the throttle pedal because i feel the electronic throttle is far too laggy and this might help. 8)
TPS ground
Re-enforcing a factory cylinder head ground
Main 4 gauge ground wire run to the battery
The distribution block
NIce grounding kit man. Whenever you want to take out that 3SGE Beams motor and sell it, let me know!
thanks 8) .....the grass is always greener on the other side...the sound and torque of the I6 is sooooooo much better.....things dont get interesting until after 5500rpm then its :eek:
added one more ground that was under the valve cover..cover :lol:
tidy'd the wires up a bit with some zip ties
