220amp is a lot of amperage. What kind of electronics are you running to need that much? Stock is like 90amp if I remember correct.
I use a Tundra alternator, it's 130amp but I'm not running a crazy ass stereo.Junkyard Sequoia alternator gang rise up
Me neither, or at least nothing a stock one wouldn't like. I got it because mine went bad.I use a Tundra alternator, it's 130amp but I'm not running a crazy ass stereo.
I just have gauges for turbo...only other electronic. I switch because my alternator crapped out finally.Me neither, or at least nothing a stock one wouldn't like. I got it because mine went bad.
Hello. What year is the tundra? I’m needing one alternator soon. Thanks
150amp option
— 27060-0F050 — 2004-2007 Sequoia alternator 150 amp OEM
130amp option (probably better for most)
— 27060-0F040 — 2003-2008 Tundra 130 Amp alternator
Factory is 100 amp. The 150 Sienna is a real good upgrade.what is the factory is300 alternator amp rating? I hope it’s close to the 130amp. Y’all really out here just putting these things in without upgrading the ground wire and charge wires?
150amp option
They both offer 150 amp. The Sienna has the option as well. If you search the forum. You will find the write up on the conversion.I'm thinking to do this upgrade, but I have some questions before I hit the yard:
@01 SolarYellow, I've seen you say "Sienna" a few times; do you mean this or do you mean "Sequoia"?
I'd prefer to go for the 150 A alternator, but no Sequoias in the yard: only Siennas and Tundras. I also read that perhaps only specific Tundra models have the correct alternator: models w/ the tow package.
It seems like the engine application is the 4.7L 2UZ-FE, with or without VVT-i, given the Wikipedia entries, but this doesn't align w/ Sienna:
The only references to the Sienna option I can find are from you. Otherwise, the only thread with specifics is the one linked above about the Tundra or Sequoia parts: High output alternatorsThey both offer 150 amp. The Sienna has the option as well. If you search the forum. You will find the write up on the conversion.
I use part interchange listings. But it was listed on the swap on the forum.The only references to the Sienna option I can find are from you. Otherwise, the only thread with specifics is the one linked above about the Tundra or Sequoia parts: High output alternators
'04 - '05 Sienna, 3.3 L V6 3MZ-FE:
'06 - ... Sienna, 3.5 L V6 2GR-FE:
- 270600P24184
Other posts reference the alternators are from Tundra and Sequoia V8 options, presumably the 2UZ-FE VVT-i models.
There are no Tundras or Sequoias in my local junkyards, but a few Sienna's, hence the inquiry.
