Thanks, yes I saw that. Is that bracket part of the auto leveling system? I was going to remove it to access the adjustment screw.There is a bracket thingy in the way though, it's supposed to make it so that both lights adjust together, but they are silly and probably broken by now. So you'd have to remove that assembly (might have to remove the head lights to get to it) and then you can adjust the screws for aim.
So, the autoleveling is a motor at the bottom of the head light, which attaches to the low beam reflector. You can see it above in the diagram where it points to the "Headlight Beam Level Control Actuator" lol. Fancy. But what that diagram does not show is the part you have to remove. Here's a picture of mine when I removed them (had the head lights off anyway)Thanks, yes I saw that. Is that bracket part of the auto leveling system? I was going to remove it to access the adjustment screw.
Correct, you don't have to install those brackets back. I never did. It just means that the high beam won't "autolevel" , though in your case, it sounds like it doesn't anyway. I never noticed mine doing it. The whole system is rather pointless and gave me way more headaches than it was worth, so I was happy to just have manual adjustment for the high beams so that they would stay where I wanted them.One last thing. You don’t need to reinstall the brackets, right? It’s only purpose is to turn both adjustment screws at the same time.
Yep, that's what it does. Always trying to keep the lights "level" depending on vehicle loading, deceleration, and acceleration.The only time I ever see any "autoleveling" going on is when I'm braking to a stop behind another car, or accelerating away from a stop while following another car, then I can see some movement of the pattern of my lights on the back of the car in front of me - more than just the normal movement you'd see if you did not have the leveling control.
