1 - 17 of 17 Posts
· Premium Member
If lexus charges alot of money for those, why are they on Ebay for like 16$
· Registered
Xenon is simply the gas used inside the lamp, creating the High Intensity Discharge.
Someone told me they're simiilar to stadium lighting HIDs, which use Mercury and sodium vapors. But if you've ever seen those lights start up, they take a good 3 or 4 minutes to light up to 100%. To solve that start up problem in car lamps, Xenon was used.
· Registered
Correct, instead of using a filament to create the light, and electrical charge is passed thru the gas to create a glowing arc. Sodium vapor lamps (Like street lamps or those in stadiums) are not well suited for auto applications due to their yellowish tinge and large ballast.
· Registered
They're fake. Xenon light requires special hardware, such as a ballast and coil because it requires a couple kV to start.
Exactly! Those cheap little blue bulbs you see in auto stores are not HID's. They may contain Xenon in the bulb chamber, but they are still filament based. Not even close to the real thing. This borderlines on deceptive advertising in my opinion.
Did you ever notice how the same wattage "blue bulb" appears brighter than a similar halogen? That's simply because the human eye has a hard time filtering blue light so it causes more glare thus appearing brighter. They actually reduce your ability to see at night... real helpful!
· Registered
The newer halogen bulbs have some xenon gas in them and these are often referred to as xenon bulbs. But they work just like the old halogen bulbs - a glowing filament. HID are filled with pure xenon gas and using extreme voltage to produce an arc that creates the ultra-white light.
· Registered
no this is incorrect. Halogen bulbs have halogen gas and a tungsten filament. No xenon gas in a halogen bulb. Some xenon lamps have filaments too, but they are called "xenon" bulbs. HID have no filament, and you are correct there.
· Registered
Originally posted by s0yb0mb:
no this is incorrect. Halogen bulbs have halogen gas and a tungsten filament. No xenon gas in a halogen bulb. Some xenon lamps have filaments too, but they are called "xenon" bulbs. HID have no filament, and you are correct there.[/QB]
Halogen Bulbs
The halogen cycle, What are halogen bulbs?
A halogen bulb is an ordinary incandescent bulb, with a few modifications. The fill gas includes traces of a halogen, often but not necessarily iodine. The purpose of this halogen is to return evaporated tungsten to the filament.
As tungsten evaporates from the filament, it usually condenses on the inner surface of the bulb. The halogen is chemically reactive, and combines with this tungsten deposit on the glass to produce tungsten halides, which evaporate fairly easily. When the tungsten halide reaches the filament, the intense heat of the filament causes the halide to break down, releasing tungsten back to the filament.
This process, known as the halogen cycle, extends the life of the filament somewhat. Problems with uneven filament evaporation and uneven deposition of tungsten onto the filament by the halogen cycle do occur, which limits the ability of the halogen cycle to prolong the life of the bulb. However, the halogen cycle keeps the inner surface of the bulb clean. This lets halogen bulbs stay close to full brightness as they age.
In order for the halogen cycle to work, the bulb surface must be very hot, generally over 250 degrees Celsius (482 degrees Fahrenheit). The halogen may not adequately vaporize or fail to adequately react with condensed tungsten if the bulb is too cool. This means that the bulb must be small and made of either quartz or a high-strength, heat-resistant grade of glass known as "hard glass".
Since the bulb is small and usually fairly strong, the bulb can be filled with gas to a higher pressure than usual. This slows down the evaporation of the filament. In addition, the small size of the bulb sometimes makes it economical to use premium fill gases such as krypton or xenon instead of the cheaper argon. The higher pressure and better fill gases can extend the life of the bulb and/or permit a higher filament temperature that results in higher efficiency. Any use of premium fill gases also results in less heat being conducted from the filament by the fill gas, meaning more energy leaves the filament by radiation, meaning a slight improvement in efficiency.
Lifetime and efficiency of halogen bulbs
A halogen bulb is often 10 to 20 percent more efficient than an ordinary incandescent bulb of similar voltage, wattage, and life expectancy. Halogen bulbs may also have two to three times as long a lifetime as ordinary bulbs, sometimes also with an improvement in efficiency of up to 10 percent. How much the lifetime and efficiency are improved depends largely on whether a premium fill gas (usually krypton, sometimes xenon) or argon is used.
Quoted from The Great Internet Light Bulb Book, Part I
Incandescent including halogen light bulbs
Copyright (C) 1996 Donald L. Klipstein (Jr) ([email protected])
http://www.misty.com/people/don/bulb1.html
Just to keep us all honest. Argon, Krypton, and Xenon are all halogen gasses.
· Registered
Ok, you got me
Here's something your internet search dind't uncover: Halogen bulbs were originally developed as industrial drying elements, and not as light sources.
· Registered
Ok, you got me
1 - 17 of 17 Posts
