Well Im trying to figure out how I would mount this intercooler that I have. It doesnt have the pre welded extensions on it. Is there anywhere I could purchase these. Here is a pic of the intercooler:
It has three threaded slots on the top and on the bottom. Thanks for the help guys.
contact Paul (TeckIS300) he can weld brackets for you. He does good work, is local, and good standing member.
It's 5 o'clock somewhere.
Just get a piece of scrap metal, bend a tab on one end, drill a hole in it and run a bolt through it into the top hole, connect this to the hood latch assembly. Do the same on two of the underside hole and find a nut on the underside of the car to bolt it to.
