White Font Slope Line Triangle
The support bracket on the transmission doesn’t really match up with the header mounting hole so I’m having issues mounting the ypipe to the header. Could I go without using the support bracket?
I was able to get the bracket to line up after loosening the header bolts and giving it a bit of room to wiggle. After tightening up the y pipe i was able to tighten the headers with ease.
These headers are semi direct fit. I’m not impress with the quality of the weld and how the header mating face was not really flush.
Also the first one I got had a weld splatter inside the o2 sensor bung hole threads which made it unuseable.
This is probably worth $1000 not the $1500 I paid. Sounds great though.
