Ok, I have looked around (including the sticky) and I am still not sure whether the following application will fit my car: (5*120 pattern)
Front: 18*8.5 offset 43 with 235/40 tires
Rear: 18*9.5 offset 43 with 255/35 tires
I am dropped with the s-techs and I am almost certain the rear application will fit, but the front may not. Please, anyone- what do you think about the fitment in the front?
Discussion Starter · #2 ·
Ok, and I know our bolt pattern is 5*114- but is there possibly a way the 5*120 pattern can be made to fit- or is there just no way- and sorry for the completely ignorant question!
Negative ghostrider! Would probably cost more to convert the car to 5*120 than your potential wheel/tire package...
aside from having the wrong lug pattern, those offsets seem to be too low, you will probably end up rubbing a lot with those specs
maybe something like 18x8 up front with a +43 offset and 225/40
18x9 in the rear with a +51 offset with 255/35
Thanks for the answers- you saved me a lot of trouble.
