Can someone help me out with a/f ratio's for a boosted car? For example what is the range it should be at idle, slight acceleration, medium acceleration, and WOT?
for N/A: 14.68:1 through all ranges
for boost: idle: 14.7:1 boost: depends, but ive seen anywhere from 11.5:1 through 12.8:1
11.5 would be ideal under boost
10.9-11.2 would be slightly better for long hwy pulls and drag racing
Mr. Negative
boosted:
idle: 14.7
over 50% throttle in the low 12's
70-100% throttle 11.5 - 11.8
IS_Dude said:
boosted:
idle: 14.7
thanks for the info.
phamous101 said:
14.7 would be too lean for WOT even for N/A applications
no, that is called the stoichiometric point, where the air and fuel mixture makes the most power on an N/A application on gasoline. When you change fuel types *meth, alc, nitrogen*, add boost, change to a much higher altitude, ect., that point then changes.
