1 - 11 of 11 Posts
i was at autozone the other days buying mobil 1 oil. i read this ad that says change your pcvp valve every 12k. i found the is300 for about $3. what does this valve do, should i get dealer or aftermarket. where is this valve located.
ps do you guys use mobil 1 for tranny or do u use toyota. any preference/quality?
Positive Crank Ventilation valve. I think it has something to do with crankcase blowby and such. You can find a detailed answer if you search Google.
Here lemme help ya:
http://www.hastingsfilter.com/engineering/tsb_94-2r.html
Positive Crankcase Ventilation (PCV)
Positive Crankcase Ventilation is a system that was developed to remove harmful vapors from the engine and to prevent those vapors from being expelled into the atmosphere. The PCV system does this by using manifold vacuum to draw vapors from the crankcase into the intake manifold. Vapor is then carried with the fuel/air mixture into the combustion chambers where it is burned. The flow or circulation within the system is controlled by the PCV Valve. The PCV Valve is effective as both a crankcase ventilation system and as a pollution control device.
PCV systems have been standard equipment on all new cars since the early sixties. Prior to 1963 PCV was only used in California. There are a variety of PCV systems used on various makes and models of cars produced since 1963, but all function essentially the same.
PCV systems can be described as either open or closed. The two systems are quite similar. However, the closed system in use since 1968 is more effective at air pollution control. The systems differ in the manner in which fresh air enters the crankcase and excessive vapor is expelled.
Open PCV Systems
The open system draws fresh air though a vented oil filler cap. This presents no problem as long as the vapor volume is minimal. However, when the crankcase vapor becomes excessive it is forced back through the vented oil filler cap and into the open atmosphere. The open PCV system, though successful at removing contaminated vapors from the crankcase, is not completely effective as a pollution control device.
Closed PCV Systems
The closed PCV system draws fresh air from the air filter housing. The oil filler cap in this system is NOT vented. Consequently, excess vapor will be carried back to the air filter housing and from there into the intake manifold. The closed system prevents vapor, whether normal or excessive, from reaching the open atmosphere. The closed system is very effective as an air pollution control device.
The PCV Valve
The most critical part in the PCV system is the flow control valve, commonly referred to as the PCV valve. The purpose of the PCV valve is to meter the flow of the vapor from the crankcase to the intake manifold. This is necessary in order to provide proper ventilation for the crankcase, while not upsetting the fuel/air mixture for combustion.
Blow-by gases and vapor should be removed at about the same rate they enter the crankcase. Since blow-by is minimal at idle and increases during high speed operation, the PCV valve must control the flow of vapor accordingly. The PCV valve is designed to compensate for the engine ventilation needs at varying engine speeds. It is operated by manifold vacuum which increases or decreases as engine speeds change.
For example, at low or idle engine speeds manifold vacuum is high. This pulls the plunger to the extreme forward position, or manifold end of the valve. Due to the shape of the plunger, vapor flow is reduced to a minimum. The low rate of the flow is adequate for ventilation purposes and will not upset the fuel/air mixture ratio.
At high speeds manifold vacuum is decreased. The plunger is only drawn to a point about midway in the housing. This allows a maximum flow of vapor. Since the engine needs more fuel/air mixture at high speeds, the introduction of more vapor does not affect performance. In the event of a backfire, pressure from the intake manifold forces the plunger to the closed or engine-off position. This prevents the backfire flame from reaching the crankcase and exploding the combustible vapor.
A neglected PCV system will soon fail to function and the result can be expensive as well as troublesome for the car owner. If the crankcase is not adequately ventilated, the motor oil will quickly become contaminated and heavy sludge accumulations will begin to form. Internal parts, not protected by the motor oil, will begin to rust and/or corrode due to the water and acids that will become trapped within the crankcase. If the PCV system is not functioning properly, the flow of crankcase vapor into the intake manifold will not be properly metered. This, in turn, will upset the fuel/air mixture for combustion and cause rough idling or even stalling of the engine. Furthermore, intake and exhaust valves, in addition to spark plugs, may well be burned and rendered useless, prematurely affecting performance and requiring expensive repairs. To assure trouble-free performance of the PCV system and, in turn, the engine and vehicle, routine maintenance of the PCV system is absolutely recommended and required.
A PCV valve should never be cleaned and placed back into service. Cleaning a PCV valve will result in a clean PCV valve; not a new PCV valve. There are contaminants that will remain in the PCV valve that can never be flushed out. Additionally, there is an amount of wear that will be experienced by the spring that cleaning cannot replace. The recommended replacement intervals are a maximum of 12 months or 10,000 miles (16,000 km). Since vehicles and operating conditions vary, the valve may have to be serviced more frequently. If it is suspected that the valve is sticking or if there is evidence of sludge, the valve should be replaced.
All hoses or tubes used in the PCV system should be cleaned and inspected. If any cracks or breaks are noticed in the hose, it should also be replaced. All hose connections should be inspected to assure an air-tight seal.
Proper servicing of the PCV valve system will help reduce overall vehicle emissions.
on top of the valve cover's...
there are two, one connects to a hose going to the intake/resonator pipe, the other connects to a hose going to the top of the intake right after the throttle body.
You have to take the engine cover off to see them.
Lemme know if you need a pic.
Kane
MannyBlaze said:
kick ass 8) . now all i need to know where is it located :roll:
thanks a lot guys. if u can please post a pic. :oops:
have any of you guys change yours yet. if yes, did u guys buy it from the dealer or after market?
pricing?
I'll see if I can scan a pic of the service manual tonight for ya'.
I haven't replaced mine yet, and I have about 26k on my car.
I looked at them this past week when my valve covers were off and they flowed fine, weren't sticky or clogged at all.
I would expect them to be about $10 at Lexus, but maybe $3-4 at your local auto parts store.
My guess is that, unless you abuse the hell out of your engine and don't change oil very often, then they might be nasty, otherwise they're most likely fine.
Kane
pricing?
I took a look at one in the '97 corolla I used to have a few years back.
The OEM one, after 30K miles, looked more solid than the Bosch replacement I bought. I decided to keep the stock one and not bother with it. It is a very simple mechanical device. The OEM one was made from meatal and the replacement was plastic. No signs of clogging were detected.
I put 56K miles on my 2001 IS and never replaced PCV valve.
Can someone post a pictures becuase i cannot find where my pvc valve is tried replacing it today but could not find where it is located. I found something that looked like it was a pcv valve it was under the cover in the middle i dont know if thats it, the difference was that this one had a nut around it while my replacement didnt. Where is this valve located and could someone post a pic please
People on LOC with other Lexus models have had some bad luck with aftermarket PCV valves. Most agree to stay with the OEM ones from Toyota or Lexus. I think the change interval is way more than 30,000 miles.
1 - 11 of 11 Posts
