I did this mod over the weekend. When i am playing the iPod, I have to turn it up 3/4 the way up on the hu to hear it at a normal level. While its playing a static sounds is coming out of the speakers....when i turn it down it goes away. what can cause this? Would a bad ground cause something like this?
I have a 3 way switch hooked up
prong 1 >>>> pink wire from cig
prong 2 >>>> 13 on realy for power
14 on realy >>> prong 4 >>>> to ground
I also did the aux-out mod for amp/speaker and it works fine. I played a cd and it sounds good. Its just when i switch over to the iPod and level is off!
Help is appreciated....thanks to those who do!
Discussion Starter #2
Nobody has any ideas...im goin to change to a two prong swithc and see if that helps!
Any other suggestions?
Double check your wire for the static problem, as for the sound level, that is how it is for everybody. 75% on Ipod and crank up the HU knob.
It is not perfect, but it is better than blowing $1,000 on a new HU.
Although there are a couple new products out there for less than $200 I think that give an Aux In. I wonder what their sound level is like.
Thanks for your reply and tutorial! I believe it is just a bad ground...i have 2 prong switch to replace the other one with 3 prongs.
hopefully that will solve the problem...as for the level i did not know that! Thanks for clearing that up.
Reactions: Squareback
Belkin makes a little charging/line out adapter, that has a little amp in it to boost the signal. I think it works great, but many people feel it is a "dirty" amp and introduces noise. I can't tell and it is good enough for me, plus I needed a charger anyway. They are about $30, but I got mine on eBay for $15.
Yeah...i have one of those...it was works fine for what it does!
thanks for the +rep.....i get ya back when i get to the green.
