I changed my plugs and wires on my 04 is300 and when I was unplugging the ignitor connector in the middle the 2 pin connector the wires pulled out and now Im not sure which color wire goes where.
Its a green wire and black with yellow stripe.
Car is down and will not run and Ive missed 2 days of work so far. Please help
Check colors of the wires on other side of the connector.
Photo ?
I can check my car if its easily accessible.
The other connectors are different color codes.
I found it, its green wire on bottom and black w/ yellow stripe on top.
Thanks
