1 - 2 of 2 Posts
Ok so i sanded down my wing bc the paint was fading bad and i went to take it off(The ONLY thing i found online about it was that the two bolts you can see from inside and 3m double sided tape) were going to be the only thing i had to deal with well thats wrong :serious:, I'm so close to having it off there is just something still holding it on near the center around the brake light I'm guessing it is located in there, IF ANYONE HAS ANY INFO PLEASE PLEASE PLEASE LET ME KNOW.
Thanks wagonfam
I know you might have gotten answers on facebook, but for future generations we should have it here as well:
Pull:
Have to remove the upper plastic panel around window to expose 3rd bolt. After the three bolts are off its going to feel like it's still bolted down, you need to pull straight up preferably by the sides of the brake light.
1 - 2 of 2 Posts
