21 - 27 of 27 Posts
Check the brake switch on the pedal.
Brake switch on pedal and brake light works.
Every time I bypass starter relay and crank sensor code will pop up. So I have the cleared code before I drive. Car run normal.
Here is the issue. Every time I shift to reverse then to Drive, car would stall.
Car would NOT stall if I shift ONLY one time to either drive or Reverse. Car would stall if I shift back to park.
I finally get push start button to turn green by wiggle the transmission shifter selector side to side.
SOLUTION-NEUTRAL SAFETY SWITCH OR SHIFTER GEAR SELECTOR????
21 - 27 of 27 Posts
