i just installed my plp intake and on cold starts it has a very hard time starting. this has happened a couple of times. it is fine after its heated up but when i start it in my garage in the morning it really struggles. is this because of the ecu still trying to learn how to work it? and it should go away after 200 miles?
It might be your ECU, no one has any trouble installing PLP Intake, its one of the easiest thing you can install... try reseting your ECU again and make sure your MAF sensor is tighten. and then try again, make sure to fully disconnect your battery for over an hour. Good Luck.
Matt :)
Nygmatic
did you reset you ECU? the car wont even run if the maf sensor is disconnected, so i doubt its that. just give your car some time to learn. it should normalize.
