Liquid Nitrogen..... you can find it in a spray can at a janitorial supply house. You spray it on the gum and it freezes the gum and you should be able to chip it off the leather. Janitors use it to remove gum from carpeting.
just get a can of air duster - (used to clean pc's). Turn it upside down and spray on to the gum, acts like liquid nitrogen. Make sure its upside down so the liquid comes out instead of the air.
Warning: It can cost frostbite so avoid contact w/ skin. test it in a small hidden area to make sure wont cause any discoloration.
air duster will work fine can be purchase at wal-mart, k-mart or any pc place. Be sure not to spray on yourself with it, awhile back i was being dumb so i sprayed myself with it and it burned me and it was freezing cold.
-ringo
