I am the 2nd owner to a 2001 is300, with about 160k miles, and have owned the car for a few years now. It is pretty much all stock. I replaced my alternator about 2 years ago.
So a few weeks ago (last time I drove the car), I was on the highway and my battery light turned on. I noticed as well that when I accelerated, the voltage meter would quickly climb up to the max value (18v) and everything would get bright. When I stopped accelerating, the voltage would fall back down to below average, and everything would go dim. I tested the battery and it came back OK. Now after a few weeks of not driving it, it wont start. I have charged the battery and even tried to jump the car to at least get it to start, to no avail. I was wondering if anyone else has had this issue, and what was causing it. I can install a new alternator if I need to, but I wanted to be sure it wasn't something else causing the issue. Thanks in advance for any help.
Bad alternator. Replace. If you are a little industrious. You can upgrade to a larger one.
Sounds like the regulator popped inside the alternator. I wouldn't drive it like that. It might bake all the liquid out of the battery. It's possible it already killed your battery and that's why it won't start now.
As the others mentioned above with the alternator, though I've only seen the regulators drop voltage when they fail a short can make them do some strange things depending on where it is. Also there is a possibility the high voltage may have popped a fuse or 2 which wont help things start.
Thanks for the replies. I changed out the alternator and that was indeed the issue. The alternator was not outputting anything. Everything runs as normal now!
