I second that... did you attempt this a few weeks ago and give up? Those before shots are horrible.Wow, how did you get scratch them so much in the first placeBTW after pics looks great
i thought heat was goodI have done this many times before to my other cars, and the thing that worked best for me was to sand with 1500 and then 2000 grit. Then I used a buffer with 3M Finnese It (the white compound)! The key is when buffing do not use pressure, heat is your enemy! Just take you time and let the compund do the work!! I was using a professional grade Makita buffer! Hope this helps.
