Hi Everyone,
Is there anyone here that is good with wiring schematics? I am rewiring my whole body harness as my car is track only and plan to only keep the absolute basics - headlights, wipers, rear running lights, brake lights, ect. I have searched and can not find the info that I need.
I have the rear running lights and rear brake lights figured out but can not figure out what wires on the low beam headlight plug need to have power and ground in order to turn on. I do not need daytime running lights, turn signals, hazards, or even high beams. I JUST need low beam headlights to work and I will be wiring these from a rocker switch to relay.
Here are the 5 wires coming off the low beam headlight plug:
Black with red stripe (not on diagram)
Yellow (DAYTIME RUNNING LIGHT)
Blue with white stripe (not on diagram)
Blue with yellow stripe (TO HIGH BEAM BULB FROM SWITCH +12V)
Blue (not on diagram)
I think you're looking at the wrong diagram. I'd get the "overall" wiring diagram for the car The head lamp circuits are fairly complicated because of the DRL relay. It supplies ground and power to the low beams. Either pure ground or ground through the DRL resister.
