1 - 12 of 12 Posts
Hey guys, I just got my HID bulbs in. I placed them in, but they still dont werk. Do any of you guys know how to werk the rely thingy. or where da fuse box is? I dont have a manual cuz it never came wid one. And I found 3 fuse boxes and headlights wherent in any of those boxes.
Also, do you guys know how to straighten ur higheams? mine looks like a huge "X" in front of me...
how about you give inspir8tor a hollar, and see what magic he can work for you, at a price of course.
wat do u mean by straighten the highbeams? u mean the leveling? if it is then maybe this will help http://my.is/forums/showthread.php?t=263893&highlight=leveling
Podiatrist
HID bulbs go in and it works.
They're a direct replacement of your old ones. No additional stuff required.
you clipped the connectors on, right? :lol:
Ya, everything in place. Do you guys think my fuses might be out? or does it have anything to do wid my relayer thingy?
Podiatrist
I'm not sure if you're being serious or not.
Putting in a new HID bulb requires 4 things.
1. Open up the back of the headlight by unscrewing the white/gray cap.
2. Turn the connector on the back of the bulb counter clockwise to release it
3. Unclip and remove bulb.
4. Put new bulb in and work backwards.
Why are you talking about relays and stuff? What else did you do?
there are fuses you can check, in the main box, passenger side in the engine bay.. But i doubt its that, unless you changed them with the lights on... which, why would you be that stupid? :suspiciou
How about you eliminate the bulbs from the equation before you go assuming there 'must' be something else wrong. When one of my headlight's went out, I swapped the other bulb to make sure it was a bulb and not a ballast. I didnt just start looking to replace a whole bunch of other crap first.
i ordered a set of 8000k D2R for my 01 lexus is300 can u give me some step by step instructions to replace them. i can only as far as taking the gray and white cap off.... HELP HELP
Sophie said it...
Podiatrist
If you need more help, PM me. It is straight forward though.
Thanks for searching first.
1 - 12 of 12 Posts
