I installed HID low beams just fine, my high beams went crazy after I installed the HID so I took them out and put the original high beams lights in and now they don't work at all and neither do the DRL I've checked all the fuses that deal with headlights and no blown fuses. Someone, please help!
have you tried bypassing the DRLs?
You can disconnect them easily
the module that controls them is above the air box on the passenger side of engine bay.
i would start there.....and then check ALL wires and connections associated with the lighting system.
No I haven't but I like having the DRL. When I hooked up the high beam HID I think I got wirers crossed cause I could never shut off my high beams.
