1 - 20 of 21 Posts
Hello all! I've been looking into getting a turbo kit for quite a while, and no decisions yet, but one thing I know is--Whatever kit I get, it's going to require a headgasket spacer for higher boost. I know anyone with decent mechanical experience can install a regular bolt-on turbo kit. The only thing that would be a little intensive is the headgasket install. So can anyone make a picture intensive step by step instruction guide on how to do this properly? Is any shop planning on showing detailed instructions on how to do this? Maybe not because they want to get the extra cash to install..............I can understand that.
I for one, would donate a little cash towards someone who is a competent mechanic to make a detailed instruction guide. This way, DIY's can save a little cash and it would definitely make things easier on anyone who doesn't live near any of these shops(like me). Any mechanics want to volunteer to make this pic-by-pic, step-by-step instruction guide? Anyone else see a need for this and willing to pay for a video or something? If there's enough need, someone will do it. Let's do this!
p.s.-even one of the tuning shops could make this video..I say someone's gonna do it eventually anyway, why not be the first one to come out with the instructional video's? Jump on an oppurtunity.
repair manual may have it ill look.
Am I Hype-R???
it better have it...specially for the price they charge for that thing...sheesh... :p
hahha youd think but the manual is maid out of low grade paper with shitty hand drawings haha.
lemme know.....Thanks! Austin
step 1 - unbolt head from car
step 2 - place new headgasket in place of old headgasket
step 3 - bolt head back on car
step 4 - marvel at your work
Your such a smart ass :lol: :lol: :lol: :wink:
strangely is basically just that. might be an unbolt a rebolt order though.
I knew GTE would probably post something to that order.........
I believe I can do it with the right tools and mechanical minded family and friends. I don't care how long it takes me, I just want to do it right. Any pointers I should know about GTE? Throw me some info!
GTE, sounds like a piece of cake. I'm sure you wouldnt mind helping out a fellow .net marylander do this, with full access to a shop and all the necessary tools- right? 8) Anyways I hope to do this very very soon but jus a little weary of doing soo, soo anyone who has please chime in.
and how much torque for the head bolts.
get the torque specs, unbolt order. The head bolts use hex keys? i forget. and of course youll have to set the timing.
Mr. Negative
I'll be up and you can do mine this weekend then. ;)
Isn't it a good 4-6 hour job to do this properly?
Threadlocker
btw don't let dirt or any other crap get into the engine while you're at it.. haha.. but actually i do believe there is a specific order for the bolts to be put on..
good question on my old car it took far longer buts its FWD.
i would bet it would take longer on a first time
its a pain in the ass to get to the bolts under the intake manifold and get all of that crap out of the way and unbolted
one of the trickiest things is setting the timing up correctly, if it isn't done properly, valves can hit pistons
-gte
so what do you need to set the timing correctly? Any special tools? Any manuals to let you know how to do it correctly?
Agreed, the first time you do anything it will be slow. By timing, I am guessing that you are referring to finding TDC on number 1? Normally there are markings on the exhaust and intake camshafts that need to be lined up as well as a mark on the Crank itself (this is for the purposes of other people not you GTE). Yes this certainly is one of the most critical things about removing and replacing the head ... but this applies to most cars. Bent valves would not be fun! Too bad we don't have the same non-interference set up as the 3S-GTE, but then again that was designed by Yamaha
All the steps should be stated in the service manual. The service manuals from Toyota are by far the best that I have seen from most car manufacturers and they are kept updated with errata sheets etc ... expensive but very worth it!
-gte
1 - 20 of 21 Posts
