im looking for the haz wire or the wire that makes the lights flash when you lock/unlock/alarm. + rep to who ever knows!!!!!!
Parking lights: 2002 IS
+ trigger Green @ Drivers Kick Panel
- trigger Red @ The head lights switch (This would be the easiest route)
Reactions: brettdotcom14
If you are installing a DEI product (Viper/Python/Avital...) Its the white wire you want to run. Make sure if you are using the neg trigger... that you change the jumper on the brain... Most DEI products you have to change it manually.
im actually installing halos and i want them to blink with i unlock/ lock the car so i want to tap into that wire.. thanks for the help guys + rep
i remember reading somewhere that the halos take some time to "turn on"...they don't instantaneously turn on when power is applied so you may not see them blink. aren't they fluorescent?..if they are then those always take some time to warm up and turn on. i would get a second opinion from AAC on this before you go hacking into the wiring.
