I would take off the door panels and check the little clamps that hold the glass to the raising mechanism
I had the same issue in mine. I had to take the whole door panel apart and expose all the components of the window. I had to put the window down all the way so that I found the white clip that raises the window had popped out of place. It took so good force to put it back in there but is a job that you and do yourself.
yeah they are connected to the metal part and then clip onto the bottom of the glass with some screws. i've had to retighten them a few times.
