1 - 10 of 10 Posts
So i bought a project is300. Everything is going fairly smooth except the headlights, the previous owner removed the OE headlights, ballasts etc and put in ebay headlights. I just want to verify that this plug is for the low beams and if anyone know which wires are power ground etc so i can hard wire in HIDs/ LEDs
Thank you in advance guys
Cherisher
Cherisher
The plugs in the other thread are integrated in the headlight. The low beam plug comes off the ballast and is routed through the housing to the bulb.
It looks like you have all the plugs. Both signals, high beam, parking light, motor and ballast power.
What are you planning to do? Replace the headlights with OEM or wire in an aftermarket ballast?
Discussion Starter #7
Correct i need to figure out which one is ballast power so i can hardwire aftermarket HIDs in VS buy oem equipment for my headlights.
Cherisher
I think it's the bottom white one below the high beam you have circled.
1 - 10 of 10 Posts
