I was just wondering if any of you have driven the IS hard, either on the street or the track and woulf like to know what your conclusions were (oversteer,understeer).THanks!!
Originally posted by sacremon:
Understeer, and lots of it. That's one of the reasons I got the TRD sway bars.
sway bars in the back? If you add sway bars in the front that'll only make it understeer more, right?Originally posted by sacremon:
what does it do?Originally posted by SPiFF:
Though you can use the throttle to get the tail to move around a bit untill the
TRD racing sway bars are 50% stiffer in front, 100% stiffer in back, so they tend to counteract the understeer.sway bars in the back? If you add sway bars in the front that'll only make it understeer more, right?
I believe that is one of the ways to induce oversteer in cars, especially those with RWD. I think it's called "trailing throttle oversteer".Originally posted by DownShift:
I've actually noticed something different than what's posted above. When taking a corner at higher speeds and lightly letting off the gas, the back end tends to slip out, and I have to counter turn the steering wheel.
Originally posted by Risk3233:
In my driving experience, the factory suspension setup can be described as fairly neutral, w/some understeer in the corners.
With the TRD race sway bars installed and increased tire pressure front and rear, the car moves into a more neutral handling style.
I think the LSD in conjunction w/the TRD sway bars creates even more neutral handling.
IMO you can get most RWD cars to oversteer w/strategic application of the throttle. This also holds true for the IS, but I wouldn't say its PRIMARY drive characteristic is oversteer.
