1 - 20 of 23 Posts
Can anyone here post a simple diagram to follow? I have sold my complete motor/turbo setup with the F10X which was out of an 01. The buyer has an 03 and he asked if I could get the diagram. If anyone can help would be very much apreciated. I see there is a tutorial on the E6 wiring, pictures no longer work though.
No diagram but
You have a +12 coming directly from batt and your grounds are hooked up. There are ONLY nine pins at the ecu that you need to wire for an 02+ and HIGH IMPEDANCE injectors:
Pin # Name/Destination *Wire Color *Haltech wire and *color
A6 EFI Relay Power *Black/Red *positive 12v * Gray/Purple splice
B16 Tach to Meter *Black *tach to meter (rpm) * light green spice
C15 Injector No. 6 *Black/White *Inj drvr 3 *green/red
cut from ecu
C16 Injector No. 4 *Red/White *Inj drvr 3 *green/red
cut from ecu
C17 Injector No. 2 *Blue *Inj drvr 3 *green/red
cut from ecu
E13 Injector No. 5 *Blue/Red *Inj drvr 1 *light blue
cut from ecu
E14 Injector No. 3 *Violet *Inj drvr 1 *light blue
cut from ecu
E15 Injector No. 1 *Red *Inj drvr 1 *light blue
cut from ecu
E25 TPS Input *White/Red *TPS *white splice
Haltech Inj 2 (blue/red) UNUSED.
Haltech Inj 4 (pink) UNUSED.
Also set the output in the software for #1,3 to 8Amp.
oh ok but there is a big grey one that is left alone and I notice inj 1,2,3 have diff colors I would of thought that 123 go with one wire and 456 with the other... but it's mismatch.246 green/red and 135 light blue.....
1 - 20 of 23 Posts
