i recently got them installed, and when i put them on, they run with the parking lights.
is there anyway to relay them so that jjust the rings go on?
Thanks
you are talking about the orange lights? if so, i wanted to do the same thing, but decided that i actually like the look of the halos with that orange glow
good question though
find an ignition wire, run it through a simple relay as teh trigger wire so whenever the keys are on the halos are on.
is there any way someone can give a tutorial to show me how to do this?
accessory=halo switched power=ignitionwire
here is a pick of the type of relay you need
go to your fuse-box with a test light and find a wire on the back that is hot only when the ignition is on. buy a wire T from your local autoparts or radioshack store to neatly tap into it. Relay, wires, and t's should be no more than $15.
for reference this is a splicer..
If you're talking about the DRL's, just unplug them from under the hood and only halos will run.
