Does anyone know if H&R require camber botls? if so where can i pick some up...
I just got an 03 is300 so im new here n gettin familar with the car.. I searched but didnt find anything..
thanks
i have h&r springs and I didnt need camber bolts that I remember
your IS has camber adjustment bolts from the factory. You can have it adjusted after the spring install but probably won't be able to get it back to factory specs. This is not all bad though; a little premature tire wear and a little better handling. The only way to fully adjust it back to OE would be to get shorter lower control arms.
