1 - 20 of 46 Posts
I was just chillin in my car. ?
The plastic piece behind bumper attached to car body a little bent, is that frame damage or fixable piece?
The 'plastic piece' you referring I think is the rear bumper support. its metal but its repairable.
I see under the trunk lid is smashed in. That is frame damage and will need to be pulled or cut/weld.
Thanks for the info, so it is all repairable? I put a lot of work into making this car run great, has 200k miles, want to get it fixed
It does not look good. There will be some frame damage. How much, I can not tell you without a lot of the stuff removed and some measurements.
What should I do? The car has sentimental value to me, and mechanically runs smooth and just did timing belt water pump radiator o2 sensors and all front suspension
I’m having trouble finding a part number for the ‘rear bumper support’ it’s not the foam part or the steel metal bar it is the painted molding behind that, that looks like part of the car frame
If anyone has any other part numbers for
Rear bumper cover
Rear Tail lights
Trunk
Would be much appreciated
(If you have on hand)
Rear bumper cover
Rear Tail lights
Trunk
Rear Bumper: 52159-53904
Rear Tail Lights: 81561-53031 (Driver Side) - 81551-53031 (Passenger Side)
Trunk: 64401-53080 (W/Spoiler)
Mr. Roo
Same thing happened to mine, except the impact on mine was lower, so the trunk wasn't that bad. But the metal behind the bumper was. They totalled it. Can't really tell what's going on there without taking it apart. If a new bumper, lights, and trunk is all it needs, then it shouldn't be totalled. But if there's damaged metal or 1/4 panels, then it would most likely be.
Discussion Starter #13
Thanks everyone! All happened a time a drive thru while I was ordering guy behind me pressed wrong pedal hit me approx 20-30 mph have some whiplash hopefully no concussion went to dr. for initial checkup.
Discussion Starter #19
I’m pretty sad about this
I recently did timing belt water pump radiator front suspension
Changed tranny and gear oils etc etc car runs smooth
Anyone know the process of getting salvage title and re-registering? If I get the parts used and put it back together?
1 - 20 of 46 Posts
