41 - 60 of 97 Posts
Super Moderator
jasonm4444 u always have good advice and quick support the only thing i notice is ilk a line that goes up and down buy the ecu box thing iv looked iv been planing to do a pressure test also just gotta wait till my bro has time to go on base lol to cold to be outside iv looked i know the timing belt and water pump were done because they both look fairly new i was starting to consider the motor thing everyone suggest because its not the ac drain tube thats what i did first
Thanks for the comment, it's appreciated. I kinda confused by what you ment about a line near the ECU, the only thing I can think of is either the trans cooler lines or refrigerant line. There's nothing else around there coolant system related. It's a good idea to do a compression test/leak down any time you have a motor consuming excess oil or coolant and can't physically see a leak. I'd keep an eye on it until then.
ill try to get a pic to show u cuz i know its hard to explain yhea iv been with the honda game for so long i know coolant can be your worst enemy lol yhea now that i have some time I'm bring to get all the kinks out the car
adding to the mix
I have the gurgle sound and found some tips here, but i also have a couple of other questions...
1.-sometimes when i turn the heat on the a/c light comes on and i have to push it to go off????is the a/c comming on for a reason...
and it seems like even when i have everything turned off i still have iar comming out of vents.....not really that big a deal, but i just wanted to know if i should be concerned enough to take it to a shop???
as for the soungd of water behind the dash...im changing all fluids today and i will bleed the system when i do the cooland flush and fill...
Super Moderator
Sounds normal to me. When you turn on the blower and pass Auto, the compressor and A/C come on and then you have to push the button. The blowing air could simply be from outside air mode. Check that the air inlet mode switches and makes a difference.
I just got my car back from getting the timing belt and water pump replaced and now i hear this water noise. I tried parking my car on a hill with the heat on for about 20 mins and the noise is still there. What am I doing wrong? Also how do you know when the thermostat opens up? Thanks for your help.
Super Moderator
Air loves to trap itself in our system. I have had the same issues and had to use a more progressive method. Try bleeding the system with the car on an incline and leave the radiator cap off(start will cool car). I drain about a quart of coolant out or the rad drain so it doesn't overflow. Then allow the car to come up to operating temperature and then you'll see coolant flow. Another method is using a tightly fitting funnel at the rad spout. This ensures it doesn't overflow. I made this thread when i had similar issues and i use a funnel to bleed it, then no more problems. I use a funnel now because I'm too lazy to drain. I believe Lexus techs use a similar funnel for expansion.
http://my.is/forums/f87/infamous-gurgling-behind-c-need-help-plz-415033/
Oh, thermostat opens up between 176*-183*F (80*C-84*C)
the rad fans come on at 203*F
Make sure you have coolant in your reservoir!
Super Moderator
You'll know when the thermostat opens up when the bottom rad hose gets as hot as the top, or if you are bleeding it with the cap off, you'll see flow from right to left when it opens. It happens right before the needle on the coolant gauge hits the middle.
I just checked and there was no coolant in the resevoir. Do i take the coolant i drain from the radiator and put it in the resevoir or do i buy more coolant and put it in?
Super Moderator
You need to buy and add some. Once you do it will most likely cure the air in the system. Since your reservoir ran dry, i always recommend checking it when the car is cold so you know you aren't consuming any coolant(over next few weeks). This is a very common problem once that tank runs dry.
Make sure you use the coolant that's already in it. Either the red long life or pink super long life. Don't mix aftermarkets.
its crazy iv been dealing with the something since i got the car ilk 6 months ago i top off the radiator and resivor every couple months must not be doing it right cuz it eventually comes back every so often
I had the same issue and it took me about a week to figure it out. These cars have 2 A/C servos. They control 2 things - the direcion the air is routed through the A/C system and the speed at which the fan goes. It is tied to the Auto Climate Control. I have found this to be the issue, fixed it, and replaced the other servo when the same noise came back, fixing it again. No problems since.
IT IS NOT ANYTING DEALING WITH COOLANT, IT IS THE A/C SERVOS. This is definitive info that I figured out (being a mechanic of 10 years) and I promise it will fix your issues. These cars have issues with the servos, and the dealer sells the parts alot. They go for like $170 each. Hope this helps
Super Moderator
I ad the same issue adnd it took me about a week to figure it out. These cars a\have2 A/C servos. They control 2 things - the direcions air is routd through the A/C system and the speed at whic the fan goes. It i tied ino the Auto Climate Control I have found this to bethe issue, fixed it, and replaced the other servo when the same noise came back, fixing it again. No problems since.
IT IS NOT ANYTING EALINGWITH COOLANT, IT IS THE A/C SERVOS. This is definitive info that I figured out (being a mechanic of 10 years) and I promise it will fix your issues. These cas have issues with the servos, and the dealer sells the parts alot. They go for like $170 each. Hope this helps
Didn't get to read it all but i wanted to correct some things. The AC uses 3 servo(air inlet, air mix, air outlet), fan speed is controlled by electronic box which is a reostat. You are right in that they've been known to cause issues, usually with linkage because it's plastic same as servo internals. They can be lubed sometimes to fix, otherwise they get replaced. The gurgling issue is totally different. Yea, they definitely aren't cheap either.
By the way, air in the coolant doesn't cause noise, it causes inaccurate thermostat readings or odd heater operation.
Next time you hear the noise, look to the left side of the glove box with the glove box open, you will hear the noise just behind he glove box on the left side. If you reach back there and tap on the little black boxes with the white arms on them (servos) the noise will stop or you will feel the servo clicking. The gears in these boxes turn to adjust the vent flaps and change the A/C from floor to dash and so on. These gears get worn out and the arms will no longer move properly causing them to click. Try this and let me know what you find.
Super Moderator
Just to be clear, the IS is notorious for both problems and there are probably over 100 threads on each, maybe once a week. lol
I'm not saying at all that the servos can cause noise and need repaired, you covered the one end. I think in OP's case he had a coolant issue. Gurgling was the sign that said coolant. Both occur behind glove box area.
Gotcha, well I would have described the servo noise as gurgling, sorry if I assumed that's what it was...
Ok, just read through the thead a little further...seems there are some serious coolant issues here. I guess I jumped the gun upon readng the location of the noise and brief description.
Quick tip - be careful were you drain the coolant, I hear grass, dogs, and other furry creatures can be killed by this stuff
I'm having the same noises. I'm going to try and bleed it tonight. Hopefully it works. Thanks for all the tips in the thread.
41 - 60 of 97 Posts
