I was wondering if it was possible to run the vvti GTE valve cover on the vvti GE head? I could only find one other thread so I wanted to get multiple sources before I looked into buying it. I'm running a FF intake manifold as well so I'm trying to pretty up the engine bay.
Awesome, now can I directly swap the valve covers or do I have to change the coil pack as well? Different gaskets?
I wanna say the gasket is different. You will have one spot on the new cover that won't get screwed down but it should be fine. Some ppl will weld a spot to bolt it down but
I did not
