1 - 20 of 22 Posts
Well I have been mostly focusing on IG and YouTube but figured I would share some knowledge. It can be done with minimum modifications to the upper and looks pretty decent. I took it upon myself to do a wire tuck and clean up the harness but would be happy to answer any questions one would have.
Cherisher
I thought it was the same block minus the oil squirters...?
Pretty sure the Simpsons did it already.
Anyway, nice to see a custom build instead of a kit-kid :approve:
Blocks are the same, except like you said - few small differences. He's got a GE head still. He's mated a GE lower intake to a GTE upper intake to get the FFIM. Looks badass too!
Cherisher
Got it! Haha
Last time I saw that was when a member made an adapter plate. Yes, more info would be helpful to know what's going on.
Yessir more info please! Like Blkdout, I too thought there was more to it - machined adapters and such.
Got any pics of the process?
Discussion Starter #7
I am still making the video for my YouTube channel. I recently had surgery on my nose so I can't work on it right now. No adapter plates needed. I had to add material to the outer holes of the 4 middle runners on the upper and oval out the 4 outer bolt holes on the upper. I used the factory GE gasket to figure out how. I will link the video once it's done. I should have the video done sometime next week.
Discussion Starter #19
I have a set of GTE VVTI valve covers and Spark plug cover coming next week so i am pretty pumped to put those on and help with the look. Then i am going to focus on the outside of the car. Sand it all down to the body work and prime it, play around with some plasti dip and see what color i want to paint it.
1 - 20 of 22 Posts
