1 - 20 of 20 Posts
Alright so I'm planning on doing a refresh on my GE this summer, And I was looking and doing GTE Pistons + Rods, and was wondering is there anything more to it? I read about head gaskets, etc and compression ratios. I'm not planning to got N/A-T anytime soon due to it's a clean car. I just want to build the engine to be reliable. *I did do a search and didn't find anything relating to my question with an answer*
delete
few questions I have would help me to help you
are you ever going to boost?
are you doing the work yourself or have a friend that will do it for cheap? or is money not an option?
I don't /plan/ on boosting the motor as of now, Thought it's a 50/50 chance I will end up doing it. And I am very mechanically inclined so I would be doing all the work myself, I've been tearing apart race engines for dirt cars for 4 years helping a buddy of mine out with his shop.
delete
gte rods, your ge pistons with new rings and a new ge head gasket
gte rods are an upgrade from your ge rods, gte pistons and gte head gasket will lower your compression so for your na application youll want to keep it at the factory 10:1
and if you are doing the work yourself you can always change gasket or pistons later for boost, personally if you are not going for really high hp id keep it with just the gte rods and run high compression boost, but that's just what I like lol
Do you know if there's any difference in bearings between the GTE and GE rods? I'm un-decided if I'm gonna use OEM GTE rods or aftermarket rods as well, Basically I'm gonna be doing a in-dept refresh. I've already got a full Aisin timing kit.
delete
don't believe there is a difference? but if you going to change rods you will buy new gte bearings anyway, unless you mean will they fit on ge crank then the answer is yes as the crank is the same for ge and gte motors, you could go aftermarket but realistically if you are not putting power to it then there is no reason to upgrade your rods, the 170hp or whatever it is wont bend the ge rods, you may as well just change rings, bearings and gaskets. save your money on rods if you not going boost, put it towards other refresher parts, on that note if you can find oem gte rods for cheap then go with that, they are more then sufficient for na applications, cheaper then aftermarket and I feel oem reliability is where its at
What's the driver for the refresh? burning oil, low compression etc? Lowering compression on an NA motor is going to make it slower than it is now. I wouldn't do that until the turbo was ready to bolt on.
delete
hence the reason it was my suggestion to only use gte rods and keep his ge pistons and use the oem ge head gasket, to maintain his compression. I go on further and suggest to even keep his stock rods since bending them on the stock horsepower is not in the foreseeable circumstantial future provided proper preventative maintenance is kept up
Discussion Starter #9
It has 306K on the motor, She's well due for it without a doubt. Plus I'd rather have the assurance of it having fresh bearings, rings, oil pump, complete gaskets done, pilot bearing, front and rear main, etc.
Why are GTE rods being recommended for an NA engine? The spindly little GE rods are plenty adequate to handle the GE - and are much lighter than GTE rods, which is an advantage.
delete
if you read through all the questions and comments you will find the answer to your question, you will also find that in this series of posts it is suggested to keep his ge rods if he does want to keep it NA for a while.
do you have any further questions???
Yes.
What did you mean by this:
gte rods are an upgrade from your ge rods...
...It gives the impression you are recommending "upgraded" gte rods to this guy, whom we both can agree, would see no benefit from same.
delete
Again I say read the post... that was giving with the intention of potentially going boost in the future, it is not rocket science. Also his original post says he wants to put gte rods to begin with... I unlike people like you who just think they know everything and there is only one way to do things I read, analyze and give an answer to his question. I will then go on to give other opinions. Unlike people like you who think they know everything and there is only one way to skin a cat.
How would you have answered his questions by simply saying keep your motor the say it is if you not going boost... he now has a bunch of scenarios and options to choose from.
Not only that I'm pretty sure hes not going to enter big dollar races where the weight of his rods are going to be so much of an advantage, stronger rods are more durable, regardless of weight. So why so much hostility? Perhaps you should go bother another post
delete
This is a forum where ideas and option and opinions can be bounced around and shared and most important answers can be given to questions, not a pissing contest of why say this why say that why do this why do that. Sad
delete
Perhaps you respond better if I lay it out for you, since comprehension is not your strong point.... no I dont agree with you about there being no advantage.... you know what the advantage is????? When he decides to go boost he wont have to RIP his motor apart again.... is that lame enough terms for you to understand????
hodgon was just asking a question. you seem like your just typing to type; go back into 'retirement' if its that traumatizing to you.
OP let me make this incredibly easy for you. figure out if you're going to NA-T in the near future or not. If youre not, there is absolutely ZERO reason for you to upgrade to GTE pistons and rods. if you do plan to NA-T in the near future. that is the sole reason for upgrading. its that simple.
you dont need GTE rods in a stock GE. you dont need GTE pistons in a stock GE. there are no good reasons to change the compression ratio in a stock motor. lowering it isnt going to help you (if you dont plan to go NA-T).
as for your bearing quesiton. heres an easy way to find out. google 'GE GTE bearing' and you will get things like this:
https://paradiseracing.com/shop/2jz-toyota/2jz-king-bearing-kit/
https://www.realstreetperformance.com/king-bearings-rod-bearings-std-toyota-2jzge-2jzgte-3-0l-cr6754xp.html
those both have your answer.
Personally I avoid them because of the daily how do I make mah fo do soopra t00 jay z33 y0! 900-jdm-hp car with $3,000 budget question. But that's just me...and it seems to have diminished quite a bit. But I just think that's just because of lack of population.
1 - 20 of 20 Posts
