21 - 40 of 140 Posts
Nooo way!! I have the pod from the imprezza i was just going to bolt it to the top of the air vents. :/
So you cut it and molded it together to kind of make it one piece and fllushed together
Discussion Starter #25
Yes, I cut it and glued on the air vents dash. then sanded and painted it.
vtecos, which brake fluid do you use? I'm planning to use DOT4 and EBC yellow brake pads (i've read they are better than green ones for heavier car) on stock brake discs.
Discussion Starter #31
I am using Motul break fluid. Regarding the yellow EBC pads they are made of ceramic. They are good only for track racing and not for daily use. they make a lot of noise. better go for red or green pads.
Ωραιο αυτοκινητο φιλε εχεις κανει πολλα και ωραια. Συνεχισε το...
Σε χαιρετω απο Αμερικη.
Translation: Great looking car, keep up the good work.
