1 - 20 of 20 Posts
Penetration Specialist
Is one really better than the other? The Greddy one is like $260, while the HKS one is like $350.
Any opinions on this?
Podiatrist
The way I see it...if you mess up the install it really don't matter which one you get. But that's just my .02 cents.
or just get the toyota factory TT headgaskets, talk to Freelance, thats what Toyomoto uses to lower the compression with their kits... 8)
That only works if you also get TT internals, which utilize lower compression pistons.
You don't really have a choice if you want to go 2mm, as HKS discontinued their 2mm headgaskets a few months ago, which pretty much leaves Greddy... but they are backordered :cry:
Have you considered a 3mm headgasket (Toyo, PHR)?? I think it runs $450, and will lower compression to 8.7:1, I believe.
-Chris
-Chris
ohhh...then what does PFS use when they lower compression on their stage 2?
hks is 360 retail as greddy is 350 retail
can be found for 250-290 depending on the company who has them in stock
the greddy is back ordered, and we have one hks 2jz left in stock 2mm
Its all the same shiet, both 2mm both made for the two companys, im not even sure you could tell the difference...
David
I'd buy the Levi's.
Just curious...does anyone know for sure what PFS uses?
I think that the HKS has a little extra foreskin on both sides of its gasket that provide a "tighter :roll:" seal?
I'd buy the GReddy one. also how low is too low a compression on the IS300 motor? I am running 8:1 on my VW Motor. what would be a good compression ratio for, lets say 20psi on a 2JZ? :wink:
BTW... I think SRT sells the head gasket upgrade for $500 on their website :lol:
Mr. Negative
redline814 said:
I'd buy the Levi's.
that's a good question. I know it's grey. :crazy:
peter farrell knows.....does anyone else?
i got mine 2mm from JUN USA... 8)
lil' IS 300 said:
is300soon's got a few HKS 2mm headgaskets for 291...So the HKS isn't as expensive as what was originally listed.
Ya Retail is 370 and hks charges 13 to ship them.
Ouch
david
1 - 20 of 20 Posts
