1 - 10 of 10 Posts
Dropped my car off at the tuner to find out why the misfires are occuring or if that is even the problem. He seemed puzzled but will attempt to duplicate the RPM and speed range. Guessed the plugs may need to be regapped? :eek:
Podiatrist
There are tons of recent threads about this. Look up all the issues lil is300 mentioned.
I am well aware of the recent posts and since I didn't install or tune the car I think it's best left up to them. Will let everyone know what they said. :)
Do you have the ignition harness? hchan had misfiring problems, when he removed the ignition harness and added an msd, the misfiring disappeared.
Podiatrist
That's not true.
His MSD hasn't been installed yet.
And he changed some settings around on the e-manage.
I just got the MSD installed tonight. No more misfiring!!! focking 2-step is off the chain yo Yea.. I ended up taking off the ignition harness since my msd can control timing anyways.
Misfires happen at exactly 10% throttle posistion. Only on vaccum not on boost. His laptop went down in the middle of fixing it via the GReddy emanage. Said that no way should I have to change anything to do with the ignition harness. Will finish on Monday and I'll post results. :)
At that point your timing advance would probably be in the 40s or high 30s maybe your advancing past the ignition window. Or maybe you retarding to much at that point.
1 - 10 of 10 Posts
