I'll be as descriptive as possible so here goes:
I got this noise on the front driver noise. it sounds like a constant wobbling tire. There is no brake pedal vibrations or steering wheel vibrations rather a pulse that is in sync with the tire wobble sound.
While I'm driving anywhere between 20-40mph you can feel it on that foot rest and the steering wheel. When I hit the brakes you can feel that same pulse on the brake pedal.
Once I start going over 40 and freeway speeds you can only here the wobbling tire sound. You can't feel the pulse anymore.
I know for sure its not:
-Uneven tire wear
-warped rotor (I've had this before and its horrible)
Any ideas what it might be?
Thanks for the help!
-Uneven tire wear
