I have the DRL in full mod and after the professional steam clean is done the DRL stay on WTF, even w/ out the key.
So, I look at the fuse and it's ok, then I was checking out the DRL relay by the passenger headlight and it seem dry.
If I leave the DRL full mod wire in it stay on w/o having the key in the ignition and then turn on low beam the High beam at full power can't turn it off!
If I take the DRL mod wire out, DRL is not on, but when turn on Low beam the High beam is full power!
Now, I take the DRL relay w/ 4 prone out w/ out DRL mod wire, there no high beam at all(which I have to drive it like this until I solved this problem)
I need your help to solved this, thanks in advance.
Sam
Sam
