I'm a visual guy, I learn better that way.
Here is a good IN CYLINDER video of the 4 stroke process (note the temp readings on the bottom left). After watching this think of all the stuff you read on this forum: ignition advance, retard, combustion temps, CAMS!!- valve overlap, interference/non-interference motors, spark plug heat range, fouled plugs, flame front, squish geometry, porting and polishing valves, slow burn, ping, pre-ignition, EGTs, etc etc. I've always wanted to see a vid like this, enjoy!
in cylinder video
in cylinder video
