So im getting code P0441( Evap Emission System Incorrect Purge Flow) which is causing it to run lean in Banks 1 and 2. What's causing it and how do I go about fixing it? Im also having a problem after I fill up on gas and try to start the car it cracks but wont turn over. Ill crank it 3 times and give it a little throttle it will start but once I let go it idles really bad before cutting off. But anytime I start my car after that it starts up fine with no problems. Not sure if the two problems are related. Any help or advice is appreciated.
441 code will not cause a 171 and 174 code. You have a hose cracked or off at the engine. That is causing the 171,174 codes. The 441 can be can be a poor gas cap seal or a bad seal on one of the purges. It can even be a crack in a hose for the evap system. Could even be the overflow vent on the tank. Or even a crack in the charcoal canister.
