1 - 8 of 8 Posts
is the getrag 6spd swap a direct bolt on to the IS300's? just make a custom driveshaft?
also are the GS400/430 LSD/Diff stronger than the IS300's or something? i see a lot of peoplewith mmod lists with GS400/430 Diffs
thanks
do a little research in the "Go Faster" section, this topic has been covered many times...
you can also try using the search link @ the top right of the page.
...and WELCOME TO My.IS!
It may bolt on to your bellhousing but you need custom tranny mounts and other stuff so NO it is not a direct bolt on...But i know of someone who did a V160 swap in his garage...
GS 400/430 Rear end are used for the lower gearing (3.27?)...Its not a DIY project unless you have bad ass fabricator/welder skills like Jesse James...
Since you are asking these questions, I hope that you arnt planning to DIY, and are planning on hiring somebody with a reputation like SRT or PFS as most people who have these mods are done by them...You realize this aint gonna be cheap either...You probably could buy a used IS for around what its gonna cost to do a V160/GS 430 rear swap...lol
i did a v160 swap in my garage yeah use the search button this topic has been covered a bunch of times any questions pm me
Just wondering, are you N/A or Boosted?..
It's 5 o'clock somewhere.
This has been covered, please search. To answer the original question....no, there is nothing "bolt on" with the v160 swap. It requires a lot of modifications.
acc the v 160 is bolt on lol
1 it bolts right up to the 2jzge engine with no bell houseing mod
2 with the sequia drive shaft it is bolt right up
3 with all the srt parts bolts right in
a amature can do it in his garage
1 - 8 of 8 Posts
