Hello my.IS members ,
Well it's the new year and I haven't put up a GB yet... I have to fix that ASAP!!
This GB is for the IS250/350 Hotchkis Suspension peices.
Please use GB Code CLGBHOTCHKIS for all items on this GB.
IS250/350 Sport Spings
GB price is $225.00
Order HERE
Features:
Hotchkis Lexus IS 250/350 Sport Coil Springs are made of high strength Chrome Silicon Steel
Undergo a stress relieving shot peening process
Finished in durable rust resistant Hotchkis gray powdercoat
- Front Coil Spring Rate = 350 lbs/in.
- Rear Coil Spring Rate = 380 lbs/in.
- Front Drop = 1-5/8” (41mm)
- Rear Drop = 7/8” (22mm)
IS250/350 Sway Bar Set
GB price is $385.00
Order HERE
Features:
Lightweight, durable 1-1/4” (32mm) tubular steel Front Sway Bar is 83% stiffer than stock
Lightweight, durable 3/4” (19mm) tubular steel Rear Sway Bar. Adjustable to 70% and 140% stiffer than stock
Unique Hotchkis polyurethane bushings
Special two stage anthracite powder coat finish
IS250/350 Complete Stage 1 TVS Suspension System
GB price is $600.00
Order HERE
Features:
Sport Coils constructed from high strength Chrome Silicon Steel, finished in rust resistant gray powder coat
- Front Coil Spring Rate = 350 lbs/in. - Rear Coil Spring Rate = 380 lbs/in.
- Front Drop = 1-5/8” (41mm) - Rear Drop = 7/8” (22mm)
Sport Sway Bars constructed from lightweight, durable tubular steel
Front 1-1/4” (32mm) Sway Bar is 83% stiffer than stock
Rear 3/4” (19mm) tubular steel Sway Bar. Adjustable to 70% and 140% stiffer than stock Unique Hotchkis polyurethane bushings Special two stage anthracite powder coat finish
GB price is $225.00
Order HERE
Features:
GB price is $385.00
Order HERE
Features:
GB price is $600.00
Order HERE
Features:
