1 - 20 of 20 Posts
hey just wanted to hear your guys input about my lil dilema...so a couple days ago my clusters started tripping in a sense that all the needles go up and down...it says my battery is at 9 or below and keeps tweaking...all the numbers disapear and maint. reqd goes on with oil light...and its dim also
thanks for all the input in advance!
in sure its just the cluster...but driving isnt affected either...maybe generator..or ground?
anyone? morning bump
sounds like a ground issue. I think the ground for is is somewhere under the radio area or something. Look it up in the service manual.
could it be just the cluster?
could be a faulty connection on the gauges? have you or has someone taken out the cluster or something? try unplugging the cluster and then make sure everything is plugged in.
did that last night..still tripping..ima take a video of it tommarow..
LOL wow, thats funny, i've never seen anything like that.
something got tweaked either somewhere behind the cluster or at the ecu or something.
you said your car was salvaged right? do you know what happened? that MIGHT have something to do with it.
yea i bought it wrecked and fixed it...changed the ecu...just started doin it a couple days ago..does it barley now..but still no good...does anyone know what else could be up with it?
bump!!
Discussion Starter · #14 ·
yea funny but really annoying...maybe i can get away with a speeding ticket..cuz now it doesnt work at all :(
not working at all is perfect! start checking wires and connections that SHOULD have power.....
I had a similar problem in a car several years ago. It was caused by a loose connection from the battery to starter solenoid. Just a thought.
Yes this is starting to sound like it was 100% a lose connection. Before it was just wiggling and shorting now its come lose enough that its not making contact at all.... or so it sounds.
yea ill check it out...is it gonna be wires from cluster or somewhere else?
have the car running (so you can watch the voltage, rpm, fuel, ect to see if the cluster is on or off or what ever) and slowly remove the cluster, if it comes back to life while you pull it you have a good shot at it being a bad cluster OR a wire going into the cluster.....
Discussion Starter · #20 ·
got it fixed..it was a loose ground behind the radio...thanks for all the input !
1 - 20 of 20 Posts
