1 - 8 of 8 Posts
I have an 02' manual is300 that seems it has a very bag lag with the pedal. If I'm idling and quickly push the pedal to the floor and back it only makes it up to 2000 rpm because of the lag. Anyone have this problem?
Reactions: cneeley
have you ever tried it any other car? I don't know how bad it is for you but compare it to some other car and you may find it to be more normal than you originally thought...
But you can do the throttle cable spacer modification (search) which helps a little bit. Also you can put on a lightened flywheel and that will help you rev quicker.
edit: longnights beat me to it and now you don't even have to search. +rep longnights.
I cant seam to get the nut on the left loose....the cord has alot of slack so im thinking its the problem....every time i try to loosen it the entire thing turns with it
Ya the throttle response is still pretty shitty but now there is no lag....i had to tighten it all the way :cool: ? throttle cable stretch?
How much does that box cost?
1 - 8 of 8 Posts
