I jus took out the fuel pump, and need the to know where the regulator is located, I was told it was next to the pump??
Nygmatic
yes, with toyota returnless setups, the pump and regulator are together. the pump pumps the fuel past the regulator, then when the regulator senses enough pressure, it will dump the excess straight back into the tank.
