1 - 2 of 2 Posts
I was recently trying to do the VSC delete mod on my 2002 is300. I had tried grounding the toggle switch I had set up to on of the bolts in the foot well. I tried starting the car and now my abs light is stuck on, VSC won't display, fuel level won't display, and the car won't shift out of park. Any information about what fuses I might have blown would be helpful, thanks!
2002 Lexus IS300
Put it back to stock. Problem solved. If not, then you may have followed someone else’s instructions wrong.
1 - 2 of 2 Posts
