I have an 01 and just got done with a complete tune up the car has 71,000 miles and i would like to replace the fuel filter. Anybody know where its located?
its located under the gas tank... its actually in the gas tank to my knowledge. To replace it yourself its kind of a bitch cause you have to run out of gas or have it pumped out. then u can swap it out. someone correct me if im wrong.
You will ONLY need to replace the filter if you have problem.. Now days filters never need changing unless you have or had problems with your fuel pump, given it has the first filter on it.
never hurts to try i guess? i was curious too because i have been looking for the fuel filter as well seeing where its connected to my rising fuel pressure regulator.
Thanx guys if its in the tank i guess it will have to stay for the time being i dont want to deal with all that just to get it out.
