1 - 17 of 17 Posts
AZNHYPNOTIQ said:
Are these ones made by chin kwan of the .net community?
They are the same thing considering he doesn't make them anyway :lol:
ohhh lol ehhh.... I dont know much about these... all I know is in a bunch of older threads everyone points at chin kwan for the adapters
sweet! we'll see how new fluid and pads work at the track. how often do you make these hk300? btw, can you translate this for me?
thanks
Discussion Starter #7
thanks
why do you need a translation? It is pretty straight forward, at the y-axis ... top is compression, lower part is rebound. However, i don;t trust the diagram, it seems to me too flat... means that the shock reacts very slowly.
hk300 said:
hey Imprimis ... did not see you online recently? Busy?
Yeah man just a tad lately :lol:
Moved a couple times, and working keeping busy
need anything just PM me or email :cool:
goohead said:
what else is needed to use the tt brake setup??
search my friend...
sigh.. fine...
-TT calipers (350-400 new) cheaper when used but you'll probably have to buy a rebuild kit from Toyota..
-OEM or Aftermarket Supra Rotors
-Pads
-Adapters ^whats for sale^
-Spacers depending on rims.. (Stock = atleast 15mm spacers)
AZNHYPNOTIQ said:
search my friend...
sigh.. fine...
-Pads
thanks for the info but i already knew all that, was wondering if there was another ADAPTER plate or somthing neededi figure with larger rotors one would need to extend the position of where the calipers bolts on to the knucle, but i guess im wrong. either way thanks
no addition parts are required
-Pads
- Stainless brake lines
Total cost is about 850-900
I did the whole shopping list with OEM Toyota and TRD calipers etc..
Just call Toyota to get a quote
Discussion Starter #15
sale pending ...
... if someone else want a set, pls pm me ... i may be able to get some more.
1 - 17 of 17 Posts
