Aquamist Water Injection Systems - $610
Part No. 806-008 System 2c
806-052 Race Version
High Pressure Water Injection Pump
250ml/minute @ 100psi minimum
I bought this for my car a while ago and never used it. As you are aware these are the best kits out there and go for top dollar($800). Please benifit from my loss and win a great injection system. You can benifit by cooling your charge air and bumping up your boost for more power. The benefits of water alone are amazing, let alone adding methanol or alc to the mix and you can reall have fun by uping the boost. It's like tapping into free power. I now have a similar kit on my Supra and I run 25psi on pump gas all day long.
Stock fuel rail - $???
stock injectors from my '01 for sale - $100 shipped
- Constant Water pressure
- Race Version Pump
- High speed Valve
- Manifold assembly
- .7, .8, .9mm water jets
- 40a relay
- Fused Wire Loom
- M8 x 0.75 tap
- 2 x 1.5mm nylon hose
- Stainless Filter
